ejf
Hi,
I hope someone can give me a little guidance here. I currently have a Lav--WC--tub---> drain configuration with the lav feeding into a 3inch pipe, then the wc, and then a 2in run feeding from the bath drain after about 4ft into this 3in pipe which continues on past another bathroom and into the main stack.
The first picture below show the 2in arm from the tub p trap to the 3in main. I'd like to add a shower drain ptrap and short arm to this 2in run and vent the 2in prior to the shower wye.
The complication is that I plan add a vent to this 2in arm by inserting a rolled a 2x1.5x2 santee at 45deg and bringing a 1.5 in pipe off that under the floor to the wall where you can see there is a 1.5in vent ascending from the kitchen sink in the floor below. I would go through the floor plate and after a 90 bend ascend to 6in above the lav height before tying in to the vent. Does this sound reasonable?
The 1in pipe you see is the "vent" from the tub/shower in the guest bath. That will get cut out and done properly (original construction; no codes here in wild wonderful WV outside the city limits ).
The last diagram is a representation of what the final setup would be. Comments are appreciated.
