Low-profile way to fasten insulated copper tubing
Rossn
Denver, CO
I have a number of copper plumbing runs (city supply, well, irrigation, dhw & recirc, etc) that I need to attach to the underside of the joists, and will furr down the ceiling 2". Several runs will be insulated... ideally continuously.
What is the best low-profile, acceptable way to attach the continuously insulated runs (several adjacent to each other)? Can I use strapping (galvanized or plastic) over the top of the insulation, with or without a full wrap?
Rossn
Denver, CO
Thank you. I see one clip option at supplyhose. However, I only have 2.25" to fit the plumbing with insulation and also a 16 gauge piece of steel as a nail plate. 3 of these lines are 1" Copper, and that sheet shows the distance it hangs down as 1.9", and then I have another 1/2" of insulation + nail plate. I would like it to look profession did it, also have the space limitation.
Fitter30
Peace valley missouri
1/2" covering is 1" + the pipe od. One or two hole conduit clamp take some thin aluminum flashing ( roof dept) form it over bottom half of pipe 12" long to spread out the weight not to crusn covering.
Rossn
Denver, CO
Yes, though I am saying the clip hanger has a depth that includes all but one side of the insulation, and with that, it would come to 2.4"+steel, which is greater than the 2-1/4" I have to work with. Yes, the tubing+insulation does fit, in itself. Help me understand the purpose of the aluminum flashing? Just to prevent damage to the insulation?
Is it a notably bad idea to just use strapping across the insulated tubing?
Since I have to put some steel on the underside, where I have 3 runs ganged side-by-side, maybe I just cut some 12"x6" 16-gauage steel and use that at intervals, screwing through it, and into the joists... basically a sandwich. Again, maybe not conventional enough to be acceptable; almost like a cable raceway.
wwhitney
Berkeley, CA
Having a larger area of contact will reduce insulation crushing. You could take a look at the fabric webbing used for securing insulated ducts. Non standard but I don't see a problem.
Cheers, Wayne
Rossn
Denver, CO
Agreed on the larger area for insulation compression... that said more than 1.5" wide doesn't help much, given the joists are 1.5" wide. For plumbing products, Oatley makes this 1-1/2" strapping (a bit rigid). I'm assuming that despite being copper tubing, the insulation separation would make it OK with inspectors to use this steel strapping.
