Loud drain bathroom sink
J.j.cham
Canada
I have 2 bathroom sinks that are very loud (like gurgling) when they drain and bubbles come up. There is no delay with draining just noise. If i plug the overflow it will fill up. I have 5 sinks and only hear it in 1 of the master bathroom sinks and the basement. I have used drain opener and an auger but still will not go away.
I think it's a partial clog, but I dont know what to do to get rid of it. Called a couple of plumbers and they just said it was normal. It is extremely annoying and it didn't always sound this way.
WorthFlorida
Solutions
Orlando, 32828
...... If i plug the overflow it will fill up. I have 5 sinks and only hear it in 1 of the master bathroom sinks and the basement.........
Have you checked the venting? Are you saying when the sink overflows are plugged, the sinks don't drain in the master bath? The noise from the basement sink, is it from its own when draining or the noise is heard from the basement sink when the bathroom sink is draining? No noise otherwise such as when a toilet is flushed? The master bath sinks, are there two p-traps one for each sink or do they share one p-trap?
Can you provide a picture of the bathroom sink traps?
J.j.cham
Canada
Hello there is no noise when toilet is flush or other fixtures are ran. It just sounds loud when water is going down the drain. Like its rushing down quickly. There is water in the ptraps so it's not sucking it out. In the master there are 2 separate ptraps ( 1 per sink).
Can you tell us more about that?
I think you are saying that the sink will not drain if you cover the overflow holes, preventing air from exiting. I think that could be caused by a belly in the line before a real vent (not an AAV). That could be checked by running a camera down the drain path and see if significant standing water was encountered. I am not a plumber, and I have not run a camera down a drain line.
Running that camera would be easier if the trap was converted to a slip joint trap.
Was this bathroom area part of the original construction, or was it added later?
