Hello All,
I am hoping that someone might be able to help me with this issue I am having with my well pump. I know little about well & plumbing lingo but am handy enough in general. I have run into a situation where my otherwise good water pressure will be reduced to about half capacity every 30-45 seconds or so. I have watched the gaugue on my well pump and it appears that when the pressure gauge reached 35, the gauge will briefly (1 second or so) drop down to zero and then shoot back up to 50. The brief loss in water pressure corresponds to the gaugue quickly shooting down to zero. I have done some searching around the web and much over what I have read seems to suggest that my pump may be "short cycling". I have tried adding air but have no idea what PSI I should be at. I had it at 42 PSI briefly and that did not help and have also taken it down to 33 PSI and the problem is still occuring.
Another tidbit: a plumber recently came to my home and installed a new hot water mixing valve on my boiler (I have a tankless heater). The problem started happening shortly after that. Could these things be related? He did nothing in the well pump area mind you. Any help you could provide to help me correct this problem would be very sincerely appreciated.
Thanks in advance,
Paul
Thanks in advance,
Paul
