Loose handle on Essence 8" Widespread Two-Handle Bathroom Faucet M-Size MODEL # 2029700A
lkbry501
Helping a friend with a loose bathroom sink handle.
1. Need recommendations on how to get the handle off. It doesn't have any holes for screw connections, and the diagram looks like it twists on and off. Wanted to check before I gave it a good yank.
2. Once I get the handle removed, brainstorming ideas for the fix. Any feedback welcomed.
https://www.grohe.us/Widespread-Fau...-Bathroom-Faucet-12-GPM/GROHE-CHROME-2029700A
Tuttles Revenge
If you follow that link and click on the installation instructions and read the download (its not written really well IMO like most installation manuals) you will find this section.
4. Place the escutcheon O-ring (D) on the basin and screw down the handle with escutcheon (E) until it stops. Be sure that the handle points away from the spout.
5. Tighten the mounting set (B) from below to secure the valve.
Seems that you must follow in reverse. Loosen the nut from below to release tension on the trim escutcheon above. Once loosened, then you can unscrew the escutcheon with the handle to reveal the cartridge.
At least that is my take on it.
lkbry501
Thanks! I was thinking the same thing you suggested just didn't want to mess up their sink.
The handle is on really tight and I'm having trouble getting it to unscrew. Any suggestions?
Tuttles Revenge
Only suggestion I can think of is to lower the lower nut a bunch so that the top escutcheon is easier to grip with your hand or tool depending on if the faucet is ever going to be reinstalled.
