Bridges
Folks,
Attached is a logical PEX plumbing layout that I would appreciate your feedback on. In particular, would you recommend any additional pressure gauges or adding check valves? I've also tried to research and anticipate the fittings/multiport/manifolds I would need so if you have insight in that area, that would also be helpful. Home layout is a 1,600 sqft ranch. Thank you in advance.
