load bearing
Jetlag
Ga.
If you run an interior wall perpendicular to the ceiling joists on a roof system that is designed for a clear span wouldnt that be a non-bearing wall even though the ceiling joist are resting on it. I used 2x6 rafters and 2x8 ceiling joists which the inspector passed for the 18 ft span, on one end I added partition down beside stair case . The reason IM asking is I used a 2x4 flat ways for a door header which is approved for interior non bearing.
GabeS
Remodel Contractor
Brooklyn NY
18' sounds like a long span to me for 2x8's if they are 16" on center. I'm not for sure though. According to what you are saying I would agree. Since the header is a load bearing part of the wall, but in your case you are saying it's not load bearing wall. Probably better to just agree with the inspector and get it done the way he or she wants since it's not that much work anyway to install a header. Probably more of a hassle to argue and prove your point than to just do it is what i'm saying.
Jetlag
Ga.
2x8 to code
The 2x8 #2 spruce actually pass for 22 ft 4 in by IRC tableR802.4(1) . for ceiling joist on 16" centers . The inspector has not seen the header yet Im just trying to make sure before he comes. If the wall is an interior non bearing the code says it is ok .. I dont plan to argue with inspector if he says change it I will.
header
If he doesn't like it, just "box it" with 2x4's or 2x6's on edge front and back, with or without a piece of plywood between them as a spacer.
Jetlag
Ga.
Yea I wish I had used 2 , 2x4 with plywood between then I wouldnt be worried
JohnfrWhipple
BATHROOM DESIGN & BUILD
North Vancouver, BC
Pull it and be done with it.
It would take less than 30 minutes to pull the first out and rebuild it the other way.
Yes it's not a load bearing wall but any chance you have to support your framing it doesn't hurt.
