Frizzo
I have 2 older Trane Heat Pumps.
Condenser model TWY036B100A1 with ECM fan motor
Air Handler model TWE037E13FB with Variable speed motor (ECM)
The heatpump with a 40ft lineset that runs in the ceiling between the first and second floors, chatters loudly like an automatic machine-gun for about 6 seconds when thermostat is activated (both in heat and A/C). After about 6 seconds of loud chattering, noise stops, and all is fine. I replaced both (start & run) caps. The run cap. was no good. Any ideas what could be causing this scary noise? I do not have access to the lineset, as it is buried between first floor ceiling and second floor floor. The chatter only occurs on start-up for about 6 seconds and occurs about 25% of the time when starting. Thank you.
