StrongEagle
Hello,
I have a 2 inch PVC drain pipe which drains my washer. As you can see from the photo, this pipe exits the side of the house and drops through my driveway (which was installed after the drain was put in).
My problem is that as a result of the drought in Houston, my driveway has shifted just enough to have caused a crack under the concrete somewhere between just under the concrete but before the "T" that connects the drain pipe to the horizontal pipe that leads to the main sewer.
As a result, when the washer drains, water seeps up between the slab and the driveway... not a lot... but obviously a leak.
I'd rather not break up my driveway to repair a small section of PVC drain. Is there any kind of sleeve or liner that I could insert into this drain to seal the leak? Something along the lines of the liners used by municipalities to stretch the life of aging sewers?
TIA
TIA
