bigrebnc1861
mz4wheeler like I said earlier 8 out of 10 times it will work but there are those times that you will have to re-place your joint completely.
bigrebnc1861 said:mz4wheeler like I said earlier 8 out of 10 times it will work but there are those times that you will have to re-place your joint completely.
mz4wheeler said:Hmm.. Well, I *TRIED* the easy way, and the solder would't stick for nothing, even after shining up the pipe and fluxing the hell out of it [grin]. Time was running out so I gave up and I'll cut it out tonight and replace the 90. After I re-pressurized the pipe, it leaked a little worse.
My wife wasn't impressed either [grin].
hj said:One of your problems was that you did not shine the pipe and fitting inside the joint where the real seal takes place, and you did not get the flux in there either. Flux keeps the material from oxidizing when it is heated, which allows the solder to flow into the joint. When you overheat the joint and the flux itself oxidizes you have to start over.
speedbump said:Sorry I got here so late, I was going to save you all that trouble. I was going to suggest keeping the pie plate under the leak and installing a dehumidifier.
bob...
bigrebnc1861 said:My goodness some plumber didn't finish the job by wiping the joint down . This is what I do when I have a leak, I drain the line down wipe the joint down with another layer of flux, and re-solder the joint useing MAPP gas instead of propane 8 times out of 10 this will work for me. But when it doesn't I will break the joint lose by re-heating the pipe and clean the fitting with a fitting brush, and re-sanding the pipe and adding flux . BUT REMEMBER ALWAYES USE MAPP GAS IT'S HOTTER THEN PROPANE AND SOLDER'S BETTER. After you have finished the job wipe your fitting down, because after time that green buildup of flux left on the pipe will wear your joint down.
From 16 and a half years exp. I have had to fix around around 150 leaks, some mine but for the most part re-work for someone else's mistake and out of the 150 leaks 30 I have had to re-place the whloe joint with new fittings.Cass said:Just wondering Y you said 8 out of 10 instead of 4 out of 5?
That reminds me of a dishwasher repair one of our plumbers made decades ago. It was in a convent and he was sent to repair the leak. A couple of years later it started to leak into the basement again so I went to repair it. He had put a metal pan under the leak. It was a small leak and the water evaporated faster that it leaked. But he had used a steel pan instead of aluminum so it rusted out and started to leak again.
hj said:speedbump said:Sorry I got here so late, I was going to save you all that trouble. I was going to suggest keeping the pie plate under the leak and installing a dehumidifier.
So......... you just put an aluminum one back.
Cass said:hj said:So......... you just put an aluminum one back.
No, even though I was an apprentice at the time, I was the "boss" so I had to do it cosrrectly. Although I suppose I could have done like I did with a terribly "gunky" stopped up toilet once and call back and have one of the journeymen do it.
mz4wheeler said:Plan "A" was to leave the pie plate in place and see if the leak seals itself [grin].
Yes that is correct, just make sure you have the water drained off. For the most part 8 times out of 10 it will work. You can even sweat the fitting lose and replace it with a new one. But I would try re-soldering first, and then go from there. One more thing if the fitting start's to trun black that means you are burning it, and then you should replace it. I have even re-solder 3 inch copper that had a crack almost half way around the joint. The orignal connection was made by a ex-coworker
I seemed to have opened up a pin hole leak in a pipe when I installed my new hot water heater the other weekend. I've let it slowly (drop every 10min) leak hoping it'd seal itself, but so far I've not been lucky. Installed a new utility sink and drained everything a few days ago and while pipes were empty I forgot to fix it! Grrr! Tonight I wrapped a scrap of rubber around it and threw a clamp on it. Ha..I'm lazy. It's slowed down though.
(Yes, I'll fix it next time pipes are empty.)
Jason
