Leak at new washing machine supply
OneStaple
Virginia
I'm installing a washing machine supply as part of a renovation. The connection is pipe threads, and I've used three wraps of Teflon tape.
With water pressure applied, there's a small leak at the threads (at the level of dabbing it away with a paper towel every 30 seconds). Usually in a situation like this, I'd tighten it a little more until it goes away. Well, I've added about 3/4 turn a little at a time, and it seems like it's just getting worse. And it's getting really hard to turn, to the point that I'm worried about damaging the threads.
Is it possible that I have a bad fitting? Or that I'd overtightened it to begin with? Do I need to replace the copper fitting and/or the valve?
I could also remove the threaded copper piece and sweat copper pipe into the brass, but doing that so close to the plastic box always makes me a little nervous. I'm competent at sweating, but not a pro.
The troublesome connection is the one on the right in the picture.
Thanks,
Tyler
If you wrapped the teflon in the correct direction (with threads) then maybe it is Murphy's 80th sub-corillary as it relates to threaded joints.
No way to know why.
sorry
Yeah, I'm pretty careful about wrapping in the right direction. It's a bit hard to verify now though.
I'm leaning toward just removing the copper threads and sweating a new piece on, as much as I don't like doing that near the plastic. But I'm not sure I trust that a new threaded piece will do better, especially if the threads on the brass have been stretched. Although I imagine the copper would do that first.
Tyler
Personally, I would start by redoing the connection with an extra turn of teflon tape. Easy to do, and you can still move on to Plan B as needed.
If redoing, in addition to that extra turn of tape, I would also add pipe compound. Most, who suggest both, suggest tape then compound. I start with a bit of tape on the threads to help hold the tape too.
So, along the lines of your suggestions, I tried again with an extra wrap of tape (I don't seem to have pipe compound on hand...I thought I did, but it might have gotten lost in a recent move). It worked! I'm glad I have that another shot before attempting to sweat the joint.
Thanks for the suggestions!
Tyler
