Hi, prior posts my house d&v plumbing was a mess. Plumbers finally came after waiting 4 months. Totally re-done. Only connection they left was the laundry box itself (well at least til discovered had to cut to do pressure test as the plug didn't seal tightly & didn't want wait for more glue to dry) . Well my hot water line won't work leaving box where it was as no room wall get it past piping at bottom (wish wall had been built 6" instead 4"). I could shift box over to line up with drain but then need move my electrical which is perfectly placed right now in gap between washer/dryer very accessible but not have dangling cords showing (propane dryer but also wired electric) . Planned to move pex lines anyway.
My question is there an acceptable way (no inspections here) to put a jog to the left into that straight drain connecting to the box so that the drain can fit into the left hole? Without causing issues drainage! (please ignore the hot sticking in top drain pipe as just stuck it there to hold the box in place over the drain--however that is where would like hot to go). Washer box bottom currently set right at height top of washer. I could raise it slightly but electric box still in the way.
Appreciate input. If I have to move electrical I will but would prefer adjust plumbing if possible. Thanks!
