Kohler Whirlpool tub controller
cowboysunshine9
North Carolina
I have an older kohler whirlpool jacuzzi tub that will only run if you turn the breaker on and off at the breaker panel. It has a control mounted on the wall that is a Model 60350 timer. Would this be bad causing the tub to run all the time unless the breaker is flipped on or off? If it is the cause I can't find a new one so is there an option to change the timer over to a newer style? The tub itself is a Kohler K-792-HJ-45. I can't see the pump or motor to tell what they are. Thank you for your help
Tuttles Revenge
Have you tried contacting Kohler directly? I work on toto neorest and usually when electronic components fail, they need to be replaced by factory parts.
