Kohler Rialto one piece very old pita (but it's not Kohler) It's an Elger Windsor
Gleebstein
Durham NC
Hi all you plumbing gurus. Need your help. Hopefully someone has seen this toilet. I am not sure what model this is. My closest guess is a Kohler Rialto but the diagrams do not show the diverter valve setup for the bowl feed. I got a genuine Kohler 84499 1B1X kit to install but it will not fit alongside the current fluidmaster flush valve that someone previously installed. Not sure how to remove without breaking it or what the original flush setup was. There is also the very old looking diverter valve and 3/4 tubing that feeds the bowl. Also not sure the handle/lever is original to this unit. I have spent countless hours trying to get info for a full rebuild. It works and I could just rebuild the Lasko fill valve but I want it to last for a while. Hopefully someone has seen this and I can get all the correct parts for a restoration. Thank you.
I already have the kit. Problem is the fill control and flush valve are side by side. Are all the Rialto like that? On the new fill control they have flipped the rim diverter float to flush valve side so it wont clear the fill tube (or flapper). Questioning if this is the correct flush valve in the kit for this model. Also have never seen this diverter with the large 3/4' outlet tube.
No wonder why. It's not a Kohler. It's an Elger Windsor.
