Snifferpro
I have a model 50 Kinetico system.
Just yesterday I noticed i'm no longer gettting soft water.
I used a test strip to check and it's definitely hard.
I then ran the water long enough for the system to switch
tanks and checked with a strip again. No soft water.
I had a similar issue 2 years ago. In that case, I would get
soft water only from one tank. When it switched to the other
I would get hard water. Switch again and I would get soft
water. Turned out that the tube that goes down the center of the
tank had snapped a couple of the tines in the tank that would give
hard water. Had both tanks replaced and all was fine.
Now, I get hard water from both tanks.
Is there something easy I can check to see why i'm not getting
soft water?
soft water?
