Hello all. I am attempting to replace a broken section of clay waste pipe beneath my basement floor. I have it dug up and determined that the break is just to one side of a joint between two sections of the old clay. However, there is a slight angle at the joint. Not sure if it was built that way, or things have shifted over the years causing the slight misalignment. I would estimate the angle is less than 5 degrees. I had planned to use flexible mechanical couplings (yes the Fernco rubber type with hose clamps - these are acceptable here for buried applications) to replace the broken section with pvc, but I am not sure if it is acceptable to use this type of coupling on a slight angle. If not, are there other types of couplings that will accommodate the angle, or must I replace a longer segment to somehow get things to line up?
Thanks in advance for any advice!
