My water pressure is low and with the pressure control differential it drops to nearly zero before the pump restarts. If I try to set the control to a higher setting, it will run forever. I don't understand why it builds quickly to 20 but can't go higher? Please advise !?!?
More information: It has two pipes to the well. It doesn't lose pressure on its own. (I have to use the water to get the pressure to drop and recycle the pump.) I dropped the pressure with the power off and checked the pressure tank, and it has 19# in it. I believe the well is about 75 feet deep.
