Hey all...over the last month or so, in our jacuzzi tub in master bath, our hot water temp and pressure has been greatly reduced. I initially thought maybe it had something to do with the change in temperature but it’s quite drastic and even on days where temps have returned to the 60s or so, the issue persists. The cold water knob gets plenty of pressure, albeit it seems to spit it out rather than a smooth flow...the hot water knob is about 1/2 or maybe even 1/3 the pressure that it used to be. The temperature, too, is vastly reduced on the hot water knob. I don’t have this issue regarding pressure OR heat on the separate master shower just 4 feet away-so I don’t BELIEVE it’s a water heater issue...I’m open to DIY but relative newbie on plumbing...what can I do to start troubleshooting?
6’ jacuzzi tub, Delta three piece hardware set up (hot water handle, spout, cold water handle)
Thank you in advance!
