Is this fitting too loose to solder?
Smokey424
Los Angeles, CA 90040, USA
First I want to thank everyone here for sharing their knowledge. I've learned a ton and become decent at plumbing with lots of searching on these forums.
My question is, is this fitting too loose to solder. I've searched and can't really find a good answer.
I've done a little bit of soldering, but this is the first time I've had a fitting this loose. It is hard to describe so I've attached a video. Every joint I've soldered before, the parts fit pretty tight together.
This is a in-wall faucet valve that I'd like to use PEX for. If I have to, I can solder bit of copper pipe to the valve then solder a PEX adapter to the pipe; but the area I'm working in is kind of small so I'd rather not add the copper pipe if I don't have to. The copper pipe fits tight inside the valve.
video of the parts:
https://imgur.com/tDcd6I6
Thanks for any help!
James Henry
Billings, Montana.
Try a couple different fittings in the valve body, if their all loose I personally would probably go ahead and solder it or you could just exchange the valve body and tell them its defective.
Fitter30
Peace valley missouri
Stick your bushing in a sweat by female pipe thread adaptor or do not use 95/5 use bridget or a no lead solder and watch your heat.
Use a digital caliper or micrometer on the adapter. For 1/2 inch, that should be 0.625 OD.
Sorry didnt see the video befor now that Ive seen it ..... Dont measure dont do anything just clean flux and solder theres nothing wrong Good to Go!
