Is silicone lubricant needed on all o'rings for softener with Clack valve
BobbytheBus
Mass
I'm putting the softener together and I noticed the instructions only mention to use silicone on the control valve distributor o'ring. It doesn't mention to use silicone on any of the other o'rings. I also have an alternating Valve and that one doesn't mention to use silicone either on the o'rings. Should I be using silicone on all o'rings or just the control valve distributor one?
WorthFlorida
Solutions
Orlando, Florida
O rings are used in mostly two ways. One as a seal inside a pipe of fitting, the other is where the O ring is subject to torque such as a pipe union. If a surface is likely to slide over the o ring, with silicone grease it is less likely to tear out of the grove it sits in. A union connection is more likely to be disconnected for repairs, etc., thereby making it easier so the surfaces will slide over the O ring.
Pool guys use silicone grease all the time on the big O ring when insulting the cover over the pump strainer or placing the lid back on the filter after maintenance.
BobbytheBus
Mass
Thank you for sharing your knowledge. That makes sense with keeping them from getting pushed out by making them slippery and also the other for the seal. I had silicone grease and was all set to apply on each o'ring. Just got confused when the directions only specified to do one of them.
ditttohead
Water systems designer, R&D
Ontario California
When I first started in the water industry in 88, I figures you simply lubed all rubber gasket/components... anyone who has been doing this way too long will remember the 3600 bypass gasket, it was a flat seal. If you lubed it, it would simply "squish out" constantly making it almost impossible to work. It had to be completely dry to seal... Silicone seals should not be lubricated, they are water lubricated... so many things to know :)
BobbytheBus
Mass
Definitely good to know. Are black o'rings never made with silicone? Or you just know the black o'rings that come with the Clack valve are not silicone?
