cdods
When I converted to a GSHP last year I was unable to get a straight answer how how to plumb both the Iron filter and GSHP, so I just disconnected the Iron Filer. My iron bacteria problems are back - so it's time to figure this out.
The iron filter is a Culligan Rust Master (air injection) iron filter. For a number of reasons I can't have the water for the GSHP pass through the air injection "pump".
So I've come up with the following idea. Can anyone tell me if this will or won't work, or provide me with some alternatives. If you think it will work, I'd like some advice on sizing the pressure tank for the GSHP as well as how to figure out what good pressure settings would be on this pressure tank.
The idea: Tee the well discharge to two pressure tanks, one for the household water (which will run through the iron filter), and one connected to the GSHP.
After between the tee and and the household pressure thank, I'd place first a check valve (to prevent the GSHP tank from pulling water backwards through the air injector, and then the air injector).
The two pressure switches (one on each pressure tank) would be connected in parallel), such that if either or both of them dropped below the cut-on pressure, the well pump would be turned on.
So it would look like this:
------ GSHP Pressure Tank
well -|
---- Check Valve ---- Air Injector ---- Household Pressure Tank
Thoughts, comments and advice all are appreciated.
Thanks.
well -|
Thanks.
