Intermittent Tub Shower drain Leak 2 Identical Houses
Etbrown4
North Carolina
No one will believe this.
I have 2 Identical Houses with an identical 16 year old fiberglass tub shower drain in each, both leak intermittently or rarely.
The first one leaked one time through the drywall ceiling 3 months ago. None since.
Today in the other house there was a 3' puddle in the ceramic floor below this morning, yet 4 hours later, I ran water in that tub for 10 minutes and no leak.
The tub shower user swears there was no water on the floor. These units both have tight fitting glass doors.
My suspicion is the overflow, but today the user was taking a shower.
Is there plumbers putty in a fiberglass tub shower drain? Other possibilities?
Plumber69
Prince Rupert, British Columbia
Could be lots of things. Tub drain, overflow, surround seal, spout, caulking if any around spout, caulking if any around hot and cold valve, shower arm. Best to cut hole below and get some to divert water to all these spots. Even had one where it only leaked when some one was in the tub
Etbrown4
North Carolina
Diverted spout water toward overflow 5 min, and no leaks.
Stood in tub, to apply weight to tub bottom, while running water 5 min, and no leak.
Tub spout and 1 handle valve cover plate are tight to the wall.
Etbrown4
North Carolina
After trying all suggestions kindly made, it seems there is no obvious solution?
One thing I haven't tried is running water in the tub/shower, but diverting it through the shower head, so I guess there's a chance that there could be a leak in that 1/2" line.
Sometimes it's the tub diverter spout pushing water back into the wall when it tries to divert water up to the showerhead.
