Intermittent low pressure
schmmd01
indiana
I have two identical faucets in my master bathroom that are both plumbed with PEX homerunned to the PEX manifold. Sometimes I'll turn them on and get just a trickle of water coming out while other times i'll get full flow. I've yet to find a rhyme or reason to when I get the low pressure but it will do it even if nothing else in the house is running. What could be the problem, where should I start?
When one has low flow, leave that on and turn on the other. What happens?
Is there a difference between hot and cold flow in those low-flow conditions?
schmmd01
indiana
they both have intermittent low pressure. If one is low so is the other one, if one is normal so is the other one. It happens both hot and cold. I have the same faucets in my other bathrooms and i've not noticed the problem with them.
That would imply that the problem is before the water heater, I would think. Does the problem also occur in the kitchen at the same time?
Does that bathroom have its own water heater?
schmmd01
indiana
the problem is only at those two faucets. the rest of the house is fine. It acts like a restriction but it comes and goes.
It comes and goes synchronously between the two faucets, and applies equally to hot and cold. Highly weird.
