The existing drain for the washing machine is a plastic hose that goes directly into the vertical cast iron part of the main. The main then has an elbow that exits the house horizontally to a cesspool. The plastic hose leaks at that connection (middle picture). I’d like to add a vertical standpipe and have the washing machine drain into that. The lower horizontal pipe in the top picture is approximately 60” off the ground. If I add an 18” standpipe (something like the bottom picture) that would make the standpipe about 78” high. The washer manual claims it can pump water up to 96” high.
