Disclaimer: i am not a plumber. I do not know anything really about wells etc. So, some of this may sound ignorant. Forgive me.
So, I bought this house and we've been here a short while but hated the low water pressure. So, I found out the system was only sitting at 28-30 psi. I checked the air pressure in the tank and it read 34psi, which I thought was odd but I passed it off as an oddity, and here's why.
I went and bought a 40/60 switch since I've read that 50 is about average. I brought it home, cut the pump power then went upstairs and started depressurizing the system. Then I stopped that because I realized I had 2 shutoffs near the tank - one between tank and pump and one between tank and softener. I turned them both off because logically to depressurize the whole house to change a switch seemed silly to me. So, I depressurized the pressure tank then took a reading of air pressure again: 10psi. Yes, 10. And this is when I discovered the water pressure gauge was stuck on 28. So, I ran back out to pick up a gauge.
When I removed the pressure switch from the 6 inch tube coming out of the main, it was completely clogged with what turned out to be a brown powder after it dried, likely iron, right? I cleared the pipe and refitted it to the main line and installed the switch. I also installed the new pressure gauge too
During all this, I bought a doggone bike tire inflator from Walmart, you know, the kind you put between your feet and pump like crazy for a long time? Yeah, that one. And I pumped. And I pumped. And I pumped. For over two hours, off and on, to increase the tank air pressure to exactly 38psi. I also opened the drain valve between the pressure switch and tank, just to be sure all of the water was out of the tank. All of the water that I drained from the tank was some nasty water, very dark gray.
Once I got everything together again, I kicked on the pump, bled the air out of the pipes throughout the house. The pump kicks on at 40 and off at about 62. It doesnt flutter and it doesnt drop a lick below 40. So, i believe that all went fine.
Heres where i am annoyed, because. spent all day on this mainly to please my wife and she (and I, really) is complaining about discolored water. I'm getting a sort of beige water, a really watered down brown. We can run the water until it is clear but it gets nasty looking again after we leave water off for a while. This is where I ask for everyone's help.
1) how do I get my water clear again?
2) is this going to wreck my softener and cartridge filter, or the salt tank that I need to learn about?
Side note: The tank is "new" from 2009. I couldn't tell you the size but it's smaller than a 55gal drum.
