this has been a long journey trying to find my way... I picked the Grundfos 10s15-21 1 ph 230v 3 wire with control capacitor/ csv1a/ 14 gallon pressure tank, 10/3 wire. No one around here stocks these pumps. An installer wanted 1600 for the pump and i can get it online for 1025. He said he would charge for labor to install 1500: 30' from well to brick wall and 50' to wire that has a disconnect attached to a 10/2 wire that goes to 30 amp breaker box that used to be used for an electric water heater. I would need to get the pump wire, pump, tank, valve etc. There is a control box deluxe for 100 more than the standard with magnetic contractor to close circuit to benefit motor somehow. Is this worth it?
It seems a lot for an install to me. He said it's a dollar a foot to lower the pump, so 340. that leaves 1160 for the labor. Does this sound like a normal price? Living in TN
found 500' of 10/3 wire online for 466 (includes shipping) these are the specs below. is this good stuff?
Thanks guys for your help!!!!!!!
- APPLICATIONS Suitableforuseasfollows:
• For use in residential, farm and industrial water well applications
• Grounded and ungrounded water well cable systems CONSTRUCTION- Premium 600 volt cable featuring solid and stranded copper conductors with a moisture resistant plastic insulation
- Conductors are twisted and colored black, red, and yellow when supplied with three conductors and green ground
- Cable is supplied without a jacket over the insulated conductors STANDARDS & REFERENCES
• Industry standard for electrical submersible pumping (ESP) water systems • Meets NEC® code for submersible pump grounding requirements
• UL Standard 83
