Luke Reeves
I have the inspector coming tomorrow to test the water supply (100 psi for 2 hours) and drainage pipes (static water pressure for 15 minutes).
I plugged all the drains in all the right spots, filled the whole system with water from the roof vent.
I waited a while to let the air escape from the vent, then filled it to the top.
Came back 15 minutes later, level had dropped a little under 1/2 inch.
I looked at ALL THE JOINTS (everything is exposed), nothing leaks.
From your experience, will a 1/2 inch drop cause the inspection to fail?
If the inspector can visually inspect each joint?
Any help would be greatly appreciated!
