Morrelli
I've got an LP HWH that is source for two hydronic air handlers. Also have central air utilizing the same air handlers tied to two older A/C units. zoned upper/lower. I'm thinking about a heatpump retrofit as I'd rather let the solar panels power a heatpump instead of burning LP for the heat and electric on older inefficient A/C units. I would install a tankless Navien with bypass recirc for DHW as I have some long waits for hot water and no way to put in a dedicated return recirc line.
A few questions:
Am I drunk?
Can I use the existing air handlers?
Should there be any consideration for a heatpump water heater in this picture and just upgrade the A/C units ?
Northern California Sierras Weather, hot summers and rarely gets below freezing in the winter, occasional snow.
my objective is to have solar carry the cooling and heating load. I know there is a lot of missing info, but do you think even contemplating such a retrofit is feasible?
Thanks in advance....
A few questions:
Am I drunk?
