How to set up new system for well - have 240v, well 6" casing 100' deep only 5 GPM
chris8585
yreka, CA 96097
please advise if 1/2 or 3/4 HP submersible is better?
if better to reduce casing to 4"
what size pressure tank advisable?
what setting for pressure switch?
1/2 HP. Even for 7 gpm, still 1/2. For 10 gpm, probably still 1/2 HP.
I would not go to a 5 gpm submersible pump on a 100 ft deep well. A 7 would be cheaper, and 10 cheaper still. Why? There are more stages on a 5 gpm pump than a 7 or 10.
If you are having the well dug, 6 inch is much better than 4. A 6 inch gives a lot more storage. A 6 inch takes a trapezoidal pitless adapter, where a 4 inch needs a clearway pitless adapter.
Now sometimes a 4 inch PVC liner would be put into a 6 inch well because of sand etc coming in. Also, with a 6 inch casing, it is good to put a short segment of PVC pipe over the pump. This is called a "flow inducer". You can search for that term.
I am curious why you asked that.
I am not a pro.
chris8585
yreka, CA 96097
I would not go 5 gpm submersible pump on a 100 ft deep well. A 7 would be cheaper, and 10 cheaper still. Why? There are more stages on a 5 gpm pump than a 7 or 10.
I am not a pro.
thank you for your reply - this well's pump was deeper & getting dirty water & stopped so we plan to try 100 or 90'.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Moving to pump and well forum.
I would use a 3/4HP, 10 GPM pump set as deep as possible in 6" casing using a 4" flow inducer. Here is a pic.
chris8585
yreka, CA 96097
thank you for replying but i am afraid this is beyond me. Mine is a 2 person household with a low producing, 5 GPM well. I can not figure out what my pressure switch should be set at. Nor how big my pressure tank should be. We do not use a lot of water, but the water started getting dirty & then stopped so it is probably full of sand & dirt after a long dry summer so we should go on vacation when that happens & not use water. So now i have to replace pump - should pressure tank and control box & pressure switch all be replaced, too? If so what is recommended?
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
A traditional large tank and high GPM pump are seen as an additional heavy load on a low producing well. The pump runs at max GPM as it fills the tank regardless of how little the draw is. The high GPM quickly draws down the water level in the casing and the surge motivates the sediment.
The casing is your storage tank and using a small tank with a CSV will limit the GPM to what you are drawing plus 1 GPM to slowly fill the small tank.
You don't set a pump 100 ft deep in a 100 ft well.
I wonder what the static level of your water is (how far down the top of the water is when you have not been using water).
Have you ever had an indication that you pumped the well dry?
