LeslieinNorth Pole
Where can I find a basic wiring diagram for a 3/4 gould deep well pump model 2801074916? With only two live lines that feed in and five different colored lines that feed to the pump from the control box, I want to make sure that I don't mess anything up.
We disconnected a mess of wires trying to put in a new power supply as the building the pump was wired into is being moved and hubby didn't mark all of the wires.
I tried to use the diagram in the pressure switch box to wire L1 and L2 hot off of a double pole 30 amp service, thinking the M wires feed the power to the control box that the pump is wired into. I opened the control box and found the M wires are now wired into the L1 and L2 of the control box and I didn't mess with anything else as the pump had been working previous to us messing with the wires. I need to know if there is a specific order that the M wires are suppose to connect as L1 and L2 in the control box.
As the pressure in the line never dropped below 40, even when I opened a spicket on site, I figure it wasn't calling for the pump and that there must be a check valve that is keeping the pressure in the line. This pump feeds a house that is more than 150 feet away and uphill and has a secondary pump and pressure tank to deal with the head loss. Husband tried to close the contact lever on the pressure box and it made a popping noise, did we mess it up?
