How to reconnect water heater cold water inlet
Artted
Arkansas
What do I need to reconnect the child water inlet on my water heater without soldering?
You replace the flex line. Let's see the other end of the flex line.
Artted
Arkansas
The other end is soldered on. I was hoping to just put a new connector on the end that is pictured.
Dj2
California
This flex is shot. Replace it.
You will need to cut the pipe out the wall on the other end and do some soldering. Replace the shut off valve and the nipple while you're doing it.
A Sharkbite is maybe the easiest solution. You will need to cut off the end soldered and then, things will work if you have enough pipe length sticking out. You will need to make sure the pipe end is cleaned of burrs and sharp edges. THen, screw one end onto the WH, and push the other end onto the pipe and you're done.
ldon
greenville texas
I have a similar problem; if I cut off the flex copper line at the cut-off valve there will only be 7/8 inch of solid copper pipe remaining. Not sure that is enough pipe to attach a sharkbite? Any suggestions?
ldon
ldon
Find a plumber to do the soldering for you. 7/8 is too short for a 3/4 inch SharkBite.
ldon
greenville texas
The alternative would be to cut off the valve, too, and then rebuild. https://www.sharkbite.com/products/...ed-flexible-water-heater-connector-ball-valve The valve end would push onto the supply pipe after you cut it off, and the other end would screw onto the water heater.
Yes, I did consider doing that but the grounding clamp is in the way. I could move it back inside the wall, but if I use a sharkbite fitting would I then have broken continuity for the ground to the heater?
ldon
greenville texas
I did talk to a plumper and he will solder a copper male fitting to each line for $150. That's acceptable to me, but I have to get a homeowner's permit from the city to install the water heater and the permit does not allow me to get help from anyone. I must do all of the work myself if I use a homeowner's permit.
ldon
greenville texas
Trying to insert pictures, but not sure how to do that.
Ask a neighbor or two for soldering advice if you will solder.
If you are going to solder then install male adapter and use a nut x nut flex hose then you will never have solder again.
Secondly to repair a leak does not require a permit. And if it did just dont turn yourself in come on. That would be like calling the cops on yourself for removing a tag on a pillow!
To insert a picture, use the Upload a File button first before you hit Post Reply. You can't cut and paste...
Personally, if I were doing it and didn't have soldering tools or experience, I'd probably just use the Sharkbite part. You'll need about 1" of bare, clean pipe to push on the Sharkbite to the pipe after cutting off the valve. Now, if you do have a torch, you could unsolder the existing valve, while the lead is still molten, wipe it off quickly with a cotton cloth (nothing synthetic that would melt!), and maybe smooth it a bit with some emery cloth, and slide the Sharkbite on. No real soldering experience needed. The Sharkbite won't go on much (if at all) further than the socket of the valve.
