How to make removable PVC connections
Alchemizt
Mexico
Gluing everything together, the issue I have is that when I need to change things later on, I have to cut the pipe and its sometimes I have to throw away joints and valves because theyre all glued together. What would be a good way to make non permanent connections? Is this what compression couplings are for?
Breplum
Licensed plumbing contractor
San Francisco Bay Area
Compression couplings want to blow out readily and do not hold unless they have some secure way to block blow-out.
Thrust blocking is the only good way to prevent such.
Threaded brass or S.S. with unions is the only way to easily take apart.
Alchemizt
Mexico
Ah I see. What about threaded PVC, is it completely unreliable?
Pressure plumbing or drain/vent plumbing?
If DWV, https://www.charlottepipe.com/Products/Assets/02C-PVC_List_Price/CTT-818 (5-7-21).pdf is a possibility. Premium price, but you can undo or rotate.
There are also PPI Glueless Soundproof fittings. I think those are cheaper. https://www.homedepot.com/s/ppi Glueless Soundproof?NCNI-5
For pressure pipe, there are more push-fittings available for CTS (copper tubing size) pipe. CPVC is CTS, as is PEX. And of course copper pipe is CTS.
