How to I disassemble 1500 Monitor?
sgtjjj
St Louis, MO
From what I understand the handle is supposed to just slide off once I remove the center set screw and nut holding it on. They have been removed and it will not budge. I assume it's calcium buildup or is there another set screw or nut that I don't see? The acrylic handle screws off but there's nothing there to keep the sleeve from sliding off. Should I blast it with CLR? The ridged ring behind it doesn't seem to want to budge either. Hacksaw?
