How do I shock chloride a 2" deep well with packer ?
JPWHIP
Edmonton, Alberta
Can I pour the chloride solution directly down though the casing adapter into the suction pipe ? My casing adapter is pretty rusty, really do not want to take it off. Just wondering if maybe I can add a "T" fitting to the return line as the jet pump is offset from the casing adapter - so that the jet pump would suck the chloride solution into the well outside of the suction pipe. Thoughts ? Also if I open up the system will I lose prime on my jet pump ?
There is no way to sanitize below the leathers without pulling the ejector.
You could circulate chlorine thru the pipes and ejector with some effort.
