CFO
I'm remodeling my basement bathroom (on slab). I cut away about 3' of the slab to relocate the toilet and tub drain (to make a shower) and discovered that the exposed 3" pipe carrying away the waste from the toilet, sink and tub has a very minor UPHILL slope to it -- maybe 1/8" per 2 feet (see pic). We never had any problem with things not draining properly so I guess the momentum of the water was enough to push it through the slightly uphill pipe until it came to the main waste.
The existing pipe is ABS and I'll be using a Fernco coupling to switch from 3" ABS to 3" PVC near the end of the cutout. All the ABS in the pic will be replaced with PVC.
I really don't want to cut out more concrete -- I'm not sure where this pipe finds the main waste stack or how far I would have to cut before I came to a downhill slope -- I don't want to cut the slab beyond this bathroom.
Can I ' tweak' the Fernco coupling just a little to raise the PVC pipe up a half inch or so to at least give it a good downhill run before it hits the ABS. Any suggestions?
