Horizonantal sink drain above disposal drain
Siegrist970
I recently remodeled my kitchen. We added granite countertops and an undermount sink. I would like to also add a disposal but the drain from the disposal is 3 inches below the drain from the wall. I have read several threads that recommend cutting the T out and moving it down. Unfortunately, my pipe runs horizontally and is a 90 coming out of the wall from the left. Without tearing the walls apart, tapping into the main drain at a lower place and bringing it back over are there any thoughts on how I can make this work? Thanks in advance for any help!
Redwood
A great time would have been before the new counters were in.
Didn't smockwoman suggest doing that when she helped you plan your kitchen project?
Master Plumber 101
Wisconsin
Is the center of the drain from the disposal 3" below or is it the end of the connection drain piece that come's with the disposal?
drain
If the opening on the disposer is below the opening in the wall there is probably no way to make it work, since there is little variation between disposer measurements.
