Homeowner retrofit advice needed
skuhn718
Wyandotte, MI
Hello,
I’m a homeowner trying to avoid replacing the shower valve for a 3 handle setup. I am looking for advice on a retrofit kit or other option to plug-in to the existing valve, if possible?
I’m not sure how to identify what the original brand/make the valve is.
Help, please? Happy to take more pics or provide more info.
Tuttles Revenge
You're going to want to find some form of manufactures stamp on either the valve body in the wall or on the valve stems that were removed.
Most 3 handle tub/shower valves have replacement and repair parts available for them. In this case since you have the back of the wall open, you could replace the 3 handle valve with a new one as well without opening more tile. A good professional plumber could likely replace the 3 handle with a modern 1 handle pressure balance valve with a plate that covers the 3 holes.
You have options.
Id highly recomend ditching that valve . that said it probebly puts out a lot of water and good for as long or longer than your copper piping. parts both rough and trim are very likely about 95 percent chance available pull a stem, take old parts to a good plumbing store or hardware , skip past the big box store my opinion, if you choose to keep it in service. easy to change for a plumber to a modern valve
