Hey!!!! a new shower...
Royerm
Quebec, Canada
After reading and reading and reading.
I decided to replace my old 38x38 neo-angular by a 36x60.
I have included a before and after image, so much help on the forum..
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
I used to have a boss that liked the saying "it looks good from far, far from good". It does look good as a finished product but I have concerns. The wet wall doesn't look stiff enough. Is that niche cut into an exterior wall with no insulation behind it?
Royerm
Quebec, Canada
The wet wall was added a few studs, Backerboard was used and the niche on the exterior wall
is insulated,,,just not showing on the picture..
JohnfrWhipple
BATHROOM DESIGN & BUILD
North Vancouver, BC
I might suggest you install a few weep holes on the bottom side of your shower unit. I have found that there is a little build up of moisture inside the box and a few weep holes drilled in the right spot can help keep this from making things nasty back there.
JW
