Do you guys have any concerns with the current Hot and Cold supply line setup in this back to back bathroom. The shower and Sink both share the same 1/2 supply lines. I would think that if the sink in the one bath is used it would rob pressure from the shower. We havent moved into this house yet so i am not sure how the current set up affects pressure.
The current order on the Cold supply line is toilet > sink > shower. The shower and Toilet are both for the back bathroom.
Hot supply line is sink > shower
Should I tee in the Shower below the toilet and sink?
Where should i add air chambers? ive seen some added both high and low.
3rd photo is the current set up color coded for H/C
4th photo is a possible sketch, the green is for possible air chambers in either high or low locations.
