RWU
I am trying to run a waterline to a refrigerator. The house is on a slab. The refrigerator is on the opposite wall from the kitchen plumbing. It appears my easiest way to get water to the fridge would be up and over in the attic. The problem with that is freezing. Not only would that water line be small, but the amount of flow would also be extremely low (both increasing the probability of freezing in the winter.)
At the same time, I would be running this line in the exact same area as an HVAC (flexible insulated) duct.
Question- could I run my water line inside the duct? In my head I’m thinking this would keep it from freezing without issues and a little warmth isn’t probably going to hurt the ice maker.
If I did this, it would run approximately 10 feet inside the ductwork. Also, the house has a heat pump so it does not get as hot as a gas furnace.
What are the advantages and disadvantages and is this even legal or breaking any codes?
Help please.
Help please.
