jmjohn07
We are a family of 4 in a 2.5 bathroom house and recently drilled a new well that produces around 15 GPM. We have done a lot of research and contacted a few local installers but are more confused now than before - can someone help us make a decision on what system we should go with?
I tested the water and here are the results:
We contacted a few local companies and online dealers and each of them suggested slightly different things. Below are the solutions they suggested - what would you recommend given our water analysis? Thanks!
Option 1 - $2,700
Rusco sediment trapper 200 mesh
5 micron pleated 20" sediment filter
5 micron 20" coconut carbon block filter
5600SXT 32,000 Fine Mesh Water Softener
Viqua Pro10 UV filter
Reverse osmosis point of use
Option 2 - $5,970
50/5 micron 20" sediment filter
Greensand filter
Kinetico K2060 Alternating Twin Conditioner
Atlantic MP36 UV light
Option 3 - $4,497
Sediment filter
Chlorine injection
120 gallon contact tank
Pro-Ox Iron Filter 5900BT Series, 1.5 cu. Ft
Carbon Backwash 5900BT, 1.5 cu. Ft
Softener 5900BT Series- 48K Size, 1.5 cu. Ft.
Option 4 - $4,906
5 micron sediment filter
Matrixx Infusion Iron and Sulfur Removal System (H2O2 injection)
Synergy Twin-Alternating Commercial-Grade Metered Water Softener
Option 5 - $4,899
Rusco sediment trapper 60 mesh
Aclarus 8 GPM (4g/hr) Ozone System
BB pleated sediment filter 5 or 1 micron
Coconut carbon block filter
- Total Dissolved Solids: 310 mg/L
- Total Hardness (CaCO3): 110 mg/L
- pH (Std. units) : 7.3
- Specific Conductance: 530 µmhos/cm
- Nitrate as N: < 0.40 mg/L
- Arsenic: 11 µg/L
- Iron: 120 µg/L
- Manganese: 460 µg/L
- Total Coliform: > 2419.6
- E. Coli: Absent
Option 1 - $2,700
Option 2 - $5,970
Greensand filter
Option 3 - $4,497
Sediment filter
Chlorine injection
Option 4 - $4,906
Option 5 - $4,899
