monty
We have a fairly new house (built in 2011) with an irrigation back flow prevention setup that has a leak.
The risers from the buried PVC water supply pipe up to the valve are galvanized steel threaded pipe, and the supply side one now has a pinhole leak. This leak is right at the ground level where the pipe enters/exits the soil. The pipes were wrapped with insulation pipe wrap - but some water got behind the wrap and must have accelerated the corrosion on the pipe.
Now, I could simply buy a new 18" galvanized pipe nipple and install it to fix my current problem - but it seems that using galvanized pipe isn't the best choice in this area??? Should I look using something else to match the valve material? I am somewhat handy and could do the switch over and so I am curious what is the best option for this setup.
Thanks for the help in advance!
