Only In The North
I have a Weil Mclain Gold CGa 4 SPDN boiler installed in '03. This is my second winter at the home, after crazy gas bill last winter I adjusted the HIGH temp 180 and was told to have roughly 38lbs PSI. Beyond that I haven't touch anything but extensive research hasn't helped my situation.
Basically it runs way too much with the thermostat always under 68. Usually set around 64 maybe 68 on negative days. The system cannot get hotter then 160 before hitting 40 psi then kicking back on 10 minutes or so at 140 and 22psi. There are no bleeders anywhere in the house and since I can remember you can always hear water running when it kicks on and off upstairs. The piping runs from the basement to baseboards one the main level and baseboards in the second level. Roughly 15ft above boiler. Really could use some help and should be able to answer any questions about the sustem. Currently have it cold to possible start over and drain/fill adjust auto fill.. .Etc
The 90 elbows in closet is on the second floor
The two 45s are on second floor
The last image is the end of the second floor heating returning
