Jonathon
Is it still within NEC guidelines to ground electric lines to a cold water pipe? The reason I ask is because I'd often get shocked while taking a shower in an apartment that I used to rent. Not a jolt, but a strong 60-cycle tingle if you touched the water valves.
I suspect that other tenants in the building were using some sort of appliance that was grounded to the cold water pipes as per directions often included in installation procedures. It didn't happen every time but often enough that it'd really get your attention. I'd usually 'slap' the faucet with a finger to see if it was presently 'hot' before getting into the shower.
