I have a Jacuzzi bathtub to install and it says it requires:
separate GFCI, 15 AMP circuit
AND it says "using a #8 solid copper wire, ground the pump motor to the house electrical panel, or approved local ground. A grounding lug is provided on the motor"
does this mean that I need to install a ground wire from that grounding lug all the way back to the breaker box panel?
