Grohe Faucet Removal
John Evans
Massachusetts 01913
Hi ... Just bought this new house and looking to remove a low flowing worn out Grohe kitchen faucet
The faucet body is held down to the counter with a U shaped clip , I don't see a nut that locks against the clip holding it up , It seems to be threaded on and It doesn't look like it could be unthreaded because of the supply line that are inside the clip . How do I remove this ?
I have searched online and I have seen a wheel shaped install tool for Grohe faucets , Do you need this tool for removal ?
Thanks for any help
I don't know the clip, but I zoomed into your photo.
I'm not looking to replace the hose I am trying to remove the faucet completely and replace
I think I found the solution from another post on here that you remove the curved spout and that leaves the mounting shank exposed which allows you to use a wrench to tighten or loosen the faucet body .... Is this correct ?
Yes, the spout pulls off and that exposes the top nut that you unthread with a wrench or with pliers.
index.php
The top bend pulls up and off.
