Goodman Furnace won't fire
bk82388
Massachusetts
Good afternoon,
Hoping for some advice to maybe fix my 4 year old Goodman furnace. It is a propane fueled furnace.
Basically, I get error code E0 which is system lockout after trying to ignite 3 times and failing. The furnace will respond to the thermostat, begin the process of turning on, the ingnitor will glow bright orange, and then it cycles down, no flame no nothing. It does that 3 times before you get the error code. Last fall I noticed it would go through the process, light the flame for a few seconds, cycle down, and then on the second try would fire and run correctly.
My uneducated assumption from reading is it may be the flame sensor...I tried cleaning it but that did not fix it so I ordered some that will arrive tomorrow. Is there something else I should be checking?
My central AC ran fine through the summer, not sure if that rules out some things. I have attached a video of the first attempt for the furnace to run.
Thanks in advance!
Bryan
A flame sensor would not be the problem if there was no flame to sense. So I am thinking that the propane is not making it to the igniter. I am not a pro.
Plumber69
Prince Rupert, British Columbia
No propane going thru gas valve. Is the gas shut off on is the gas valve set to on are you out of propane. If all this is good then 24 volts should be sent to gas valve shortly after ignitor glows... you will probably hear a click. If you hear a click it's most likely the gas valve
Fitter30
Peace valley missouri
Bad hot surface igniter even if it glows and if doesn't pull the correct amperage as valve will not open the gas valve. When replacing it don't touch element with bare fingers. Appliance parts house might have one if you take yours in. Might find a crack in the element.
If I suspected the ignitor was not getting hot enough to light the gas, I would stick a flame there as the pilot should be trying to light. This could be a long lighter, or a pencil tip on a propane torch turned low. This assumes the space is readily reachable.
Professional , plumber, amateur at heating my pool heater once the igniter glows hear the click and main gas comes on . not a pilot not sure his furnace starts a pilot first.
but yea check that gas is coming to the gas control valve is step 1
