Stampinmommy
Please help... Where do I go next.
Woke up to water in my garage from my water softener overflow drain. The brine tank was full of water and I could hear the water was running through the inlet pipe. Checked the drain in my laundry room to find that the water was going directly to the drain. I put the softener in bypass mode and cleaned the brine tank to remove any salt clogs and water. Then checked and cleaned the nozzle and venturi. I also checked and cleaned the brine valve assembly and brine line.
Next, I put it back in service and manually advanced it through a recharge. The water level in the brine tank stays the same and the inlet water continues to drain at the same rate throughout the recharge stages. At the same time the motor runs and the cam & gear advance through the stages.
Advice on what to do next? What could be going wrong?
Thanks in advance!
Thanks in advance!
