Furnace door blew off!
Discussion in 'HVAC Heating & Cooling' started by plumber69, Feb 1, 2019.
  1. plumber69
    plumber69 In the Trades
    Jun 20, 2014
    Prince Rupert, British Columbia
    A guy called me and told me he heard a boom and his furnace door blew off. I told him to shut it down. What usually causes this. Plugged burner tubes?
  2. plumber69
    Jun 20, 2014
    Im thinking everything in the furnace has to get checked. He says its 25 years old
  4. Stuff
    Stuff Active Member
    Mar 7, 2013
    Pennsylvania
    Get some pictures. You need to do an autopsy. Door and chassis probably bent or torn. Time for a new furnace.
  5. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    That sort of "symptom" is usually traced to a small gas leak, creating an explosive mixture inside the cabinet, subsequently set off during an ignition phase when the furnace is starting.
    Plugged burner tubes can create soot deposits on the heat exchangers and poor combustion efficiency, high carbon monoxide emissions and other fun stuff, but usually not explosions.
  6. Bigmesa
    Bigmesa New Member
    Feb 10, 2019
    South Carolina
    Dana is on point. If I had to guess it would be that the gas valve is not seating all the way when the unit shuts off and causing a very dangerous situation. An wasy test would be shut the power off to the furnace and take a lighter to the orifices that feed the burners. If you light a flame you've got a bad gas valve.
  7. WorthFlorida
    WorthFlorida ?
    Oct 28, 2009
    Retired
    Orlando, Florida
    o_O Not a good way to test for a gas leak. With enough gas accumulated in the burner area or flue, it could blow up in your face. :eek: Never ever use a flame to test for leaks.
  8. Bigmesa
    Bigmesa New Member
    Feb 10, 2019
    South Carolina
    Obviously we are taking about with the cover off and aired out. If you smell a strong gas leak then soap would find it faster. But a small leak of a gas valve would not be dangerous to test this way, been doing it for a living for over 20 years and never had an incident. Again common sense goes a long way here, this would be trying to find a leak the equivelant of a pilot light or smaller.
  9. WorthFlorida
    WorthFlorida ?
    Oct 28, 2009
    Retired
    Orlando, Florida
    You always must assume you're dealing with a DIYer and can take your suggestion differently. Dale Earnhardt refused to use the HANS restraint in his cars because his head never popped out of the socket before, well guess what killed him.
Similar Threads: Furnace door
HVAC Heating & Cooling Furnace fan not kicking on until you smack the door. Jun 9, 2018
HVAC Heating & Cooling Furnace issues Thursday at 9:33 PM
HVAC Heating & Cooling Carrier Furnace Plugged secondary? Jan 21, 2019
HVAC Heating & Cooling Caulk for storm collar on furnace and water heater exhaust on roof? Jan 18, 2019
HVAC Heating & Cooling Lennox Furnace Condensate Trap Leak - Need help Jan 14, 2019
