dtherrien
Licensed Building Contractor
Its been a while since ive been on here.
Im in the process of installing two Fujitsu 18k minis. Single zone.
One is in place and set up. It will not cool. I did notice today when trying to trouble shoot that the inside of the outside compressor unit seems like it gets very hot. And took a very long time to cool down.
All wiring looks to be correct and seems to be straight forward.
Last weekend i ran it for about 20 minutes and when i noticed it wasnt cooling i shut it off until this weekend.
I let it run for about an hour...seemed to cool a little.
But then i noticed the outside unit was off and hot.
So i shut it off again. Looked at the wiring. It looks correct.
3 wires that connect the outside and inside units with a ground.
2 feed wires from the disconnect with a ground.
The only thing that im not sure if it would effect anything is the install kit come with a surge protector. Which i wired in the breaker panel to the breaker for the mini.
